NI Package Management Idea Exchange
Community Browser
Post your ideas that are related to NI package management. This includes NI Package Manager, NI Package Builder, creating NI packages (.nipkg), distributing NI packages (.nipkg), managing feeds, and more.
Post an idea
For other build specification types like executables we can use [VersionNumber] tag in the build specification. This tag is replaced dynamically at build time with appropriate value.
It would be greate to have such tags in NI package build specifications.
I can think of tags [PackageName] and [PackageVersion]
I would be interested to give these tags as arguments to custom actions scripts.
In NI package build specification, advanced section, we can use BAT / CMD scripts but not PowerShell scripts. It would be greate to be able to user PowerShell which is much more powerfull than DOS.
NIPKG.exe cannot be used in custom action scripts (ex: post-install) since one instance of NIPM is allowed at the same time.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001EA6tCAG&l=fr-FR
It would be greate if we could use NIPKG.exe in custom action scripts for example after installing a package.
As I have come to using NI Package Manager (NIPM) more, I have come across a few user experience issues that need to be improved for NIPM. This is mostly centered around downgrading package version. Most of these are currently available in VI Package Manager
  1. For installed packages, you cannot downgrade/change versions of the package. To do this, you must first uninstall the package so you can select the version you want from the Packages screen. (Installed packages are removed from the Packages screen's listing.) There should be at least an option to show the installed packages on the Packages screen so a new version can be selected. It would not hurt to have the ability to select version(s) on the Installed and Updates as well.
  2. On the Updates screen, we should be able to select the available versions if there multiple upgrades available.
  3. If you install a package that requires a downgrade in a dependency, currently NIPM does not let you install that package. It can be down via the NIPKG command line interface (CLI). There should be at least an option/prompt to allow the downgrade. This capability seems to be able to be added by NI as I was prompted to Allow Downgrade/Removal when I updated InstrumentStudio last year. Our packages should be able to do this prompting as well. At least there could be an option added to NIPM that would allow downgrades/uninstalls so that this could be done via the GUI. Also the dialog could give more information about what specifically the issue is.
Too generic message without any recourseToo generic message without any recourse
I propose to add pre- and post build actions to the LabVIEW package build spec as already present in e.g. executable build spec
It would be super nice if NI would offer all their software through winget from Microsoft.
https://docs.microsoft.com/en-us/windows/package-manager/winget/
I understand that NI invested a lot in the NI Package Manager, so this idea could still simplify our lives even if NI would just offer to install the NI Package Manager through winget.
Currently, the flow is to:
  • Go to ni.com
  • Login (if not already logged in)
  • Go to the download page
  • Search for NI Package Manager
  • Download
  • Install
Using winget, a command like:
"winget install NI.PackgeManager"
would be the only thing to do to to install it.
Here is what's available currently through winget: https://winget.run/
Let's say you have a really busy day and you need to test an application, but you need to install the LabVIEW or any other application like Test stand, for example, you go to your computer and use the Package Manager to install it. Then you have to go to another office, meanwhile, you let Package Manager take care of the installation that takes around 4-5 hours.
When you are back ready to run that test you found that there is an error saying that you have not stored available to install the software, and you wonder why NIPM did not check that requirement? There are literally thousands of software that have always performed that check before the installation some of then show a warning or they simply do not allow to start the installation. We really need this on NIPM.
Please help me with these guys.
When you create a solution with Ni Package Builder, you have the ability to create a Local Repository for a feed.
Everytime you build it it replace all.
For me, we missed a functionnality to update a feed. A feed is able to handle multiple version of a package, if you replace all, you lost the history.
Without this functionnality, you cannot mix sources of the package for the feed. In my case, I have a feed that contains package build with TS deployment tools and packages build with NI Package Builder. To include both packages, I have to build my own tool. If NI Pacakge builder was able to update existing feed, I can build all the packages of my solution and push it to the feed in one way.
Just hoping that i will have feedback !!!!
When you add  folder in NI Package Builder it add all the files included. It can be usefull to remove automatically somes files or folder with filters.
Just to give some examples. I have to include some Python Script. Python is generating *.pyc files in _pycache_ folder. If I have the ability to exclude automatically a list of extension file, or file/folder of list based on regular expressio, it can be very usefull.
My source code is under SVN source code control. When you selet a folder, it populates also hidden folder. So it adds my ".svn" folder.
Add ability to exclude hidden folder and have the first filter will help me better manage my files to distribute. This can be added to the propoerty page of the input folder.
Best regards
I'm facing almost the same problem as mentionned in this thread of the Forum : NIPB: Custom location for ProcessingStage folder - NI Community
I'm working with TestStand Framework. When building sequences for specific projects, we have a dedicated repo and we build a package to deploy that project on the target PC. The source of the project and the PBS file are in the same folder hierarchie to simplify Source Code Control.
By creating the ProcessingStage folder in the folder of the pbs you have a copy of your TestStand sequences and code modules with a risk of that you have in the same based folder the sources and the temporary files generated by build in the same location. When developing you have a risk to point on the wrong file when teststand is searchning for a file based on search directories.
If we can't change the processing stage folder destination (information is already present in the xml of the PBS file) can we imagine to add at least an option to delete the Processing stage folder after build.
Without ability to change this destination, we have to manage folder to exclude from SCC for temporary files that serve nothing after building the package.
Best regards
Because I have the situation below posted in the forums, I thought it would be a great improvement to down-rev a package without first having to un-install said package and end up removing packages that list the subject as a dependency.  That way if I ran into an issue with an update, I could easily revert to the previous package without affecting any other packages.
Thanks!
DGriffithJr
https://forums.ni.com/t5/NI-Package-Manager-NIPM/I-want-to-uninstall-a-package-and-NOT-uninstall-its-dependencies/m-p/4041272#M423
Inside NI Package Builder, you can define different packages for a solution.
Because you have a lot of option to configure and many are more just for information, it can be easier to be able to copy an already existing package than start from 0 for each package.
I don't think it cost a lot because .pbs are XML based. I don't want to build my one tool and modify the xml to be able to do that.
If I use NI Packet Manager to update a licenced part of the NI software, it will ask me - after the update has finished - to re-enter the licence data, although a valid license was already in place.
Idea: If a valid license is active, you should be able to update the packet without having to redo the licensing proces.
Right now I can only add package dependencies that are either
(a) Currently Installed
(b) In the solution being created
It would be extremely useful to:
(a) Select a package dependency from disk
(b) Select a package from a currently registered feed
On a development system, I often DON"T want to actually install the packages i'm developing, and if I have several related "solutions" I need a way to define dependency relationship between them.
Right now I either have to develop everything in the same solution (which means every time I build, it builds everything), or am forced to install the packages that I want to include as dependencies.... neither of which are desirable behaviors
Inside a solution, you have to build all the packages inside the solution.
If you split your project in different packages, it's easier to manage it inside only one solution for managing dependecies between packages. But building a fix of a small package will force to build all packages. So if you don't want to change version of other pacakges, you need to manually manage all the version by hand and make sure you are not replacing the previous pacakge that you don't want to rebuild.
Having abaility to rebuild only the selected pacakges, willl help to create patches for only a part of a bigger project well divided in smaller components.
MaximeR
I want to distribute my packages with a specific feed. This can be very usefull to distribute application to customer and push updates. But if we use a specific feed, it's not straightforward. We can use the nipkg CLI command to add/remove the feed but it's not so easy to deploy to customer. It's often more easy to request IT to let NI Package Manager to have Admin right than to allow bat file for example.
So my idea is to give ability to install a package that also register the feed. After install the package, it can have access to updates more easily. If he uninstall the package it can interresting to unregister the feed. In this way, it can be also easy to update the feed by pushing an update of the package.
Note : I tried to do it with pre and post install command without success.
Best regards.
This feature is available in the LabVIEW package builder (very cool!), but it would be helpful to have this exposed in the NI Package Builder UI as well...
Currently my work around is to either
(a) Use the SystemLink REST API and (really requires a good development pipeline for automation)
(b) Target the feed at the SystemLink internal repository folder, which will create a "hidden" repository that is unavailable in the SystemLink Browser, but can still be referenced... While not too terrible for testing, this is probably not a great approach from a security point of view...
In the Item View, if some files are insert in a folder, you need to open all folder to make sure your solution is up to date :
Why not add the Blue Dot to the folder too :
I don't know also if it's a good idea to allow to have file in multiple location in this view. This can be confusing.
Regards
I'm not 100% sure on the proper terminology, but certain URLs meant to download files in your browser don't contain the filename in the URL, rather there's an http header "filename" that presumably the browser uses to decide the name of the downloaded file.
Basically I'd like to "feed-add-package" the package hosted at this URL, but nipkg.exe rejects it because the URL doesn't end in ".nipkg." So NIPM would need to be slightly smarter and accept this "redirect" to the actual filename.
What I'm specifically trying to do is host the files in the package registry on our GitLab, and I think this may be the only thing preventing that from working.
I had a issue on Windows 11 where the NI-MAX configuration got corrupted. An NI Technical Support Engineer advised me to set the NI Device Loader service to 'Delayed Start' and change the 'Recovery' tab to 'Restart the service'. That solved this issue.
But the problem is that using NI Packet Manager to repair or install things, this NI Device Loader service is sometimes reset to ‘Automatic’ and then also the ‘Recovery’ tab is back to the default values. So we must check those settings every time after using the NI Packet Manager.
Idea: If a service is already there, NI Packet Manager should not change the properties of that service.
