The Daily CLAD
Community Browser
Rif.: CLAD2017 - Fundamentals - You are scheduled for deletion
SercoSteveB
What are the contents of Numeric Array Out following execution of the VI?
Comments
Bcortes
NI Employee (retired)
The right answer is B and here I explained it:
crossrulz
Knight of NI
B
By the way, the length did not need to be wired up.  It will default to 1 element.  Also, if length is Unwired, the "Deleted Subset" will be a scaler instead of an array.
Combine that with an unwired index and you have a very simple way to get the last element of an array.
GCentral
vidya1825
B
P Vidya sankar,
sankar06
B
Happy to Wire
nik35324
B
A.Bernau
My first try was wrong: I thought there must be a scissor in the symbol in the Delete From Array Function. Without a scissor I recognized the function as an Array Subset function.
CLAD2017 - Hunt the function: Array 4 of 5 (‎11-06-2017): https://forums.ni.com/t5/The-Daily-CLAD/CLAD2017-Hunt-the-function-Array-4-of-5/ba-p/3690723
For my sense it is quite hard to recognize a function name from the symbol only. Especially if we have different symbols for just one function in the palette, in the help file and finally several symbols in the block diagram depending on input signals 1D or 2D and so on …
So after I learned it isn’t Array Subset my result is same as all the others: Answer B (OK, I have to admit with the caption of the DCLAD it should be clearer)
SPK91
B
Baltur
b)
பரத்_குமார்(bharathkumar)
b
Thanks & Regards,
Bharath Kumar
GCentral
Nino_Marino_89
The answer is B!
O.T. :
Hi guys!
It's my first post in this forum. I passed the CLAD certification exam last week, and I want to say thank you to SercoSteveB for his work and his patience!
SercoSteveB
Hi Nino_Marino_89, congratulations nice one.  If you have a spare 5 minutes could you please post your CLAD Exam Experiences here?
Steve
mini09
B
levonsg
B
https://images.youracclaim.com/size/340x340/images/2edb5b1a-9414-44e1-8519-c774fc6dd079/36015_Certificate_Badges_FINAL__1__NI_Instructor_v5.png
Gayathri1999
Option B is the answer.
Krishna_kp
The answer is B
Gayathri1999
rak84
B
Tamir87
b
istan0227
B
