The output data type of Boolean array to number can be changed by right clicked -> property. The default output is U32, hence the red dot on U64 indicator.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Which means the answer could also be A if it had been changed to have type U16 or I16, or D if it has type I64 - all of these would still show a red dot.
The unwritten rule of The Daily CLAD (well not written for about 200 posts anyway), and coincidently my favourite get-out clause, is that if the question doesn't explicitly state a change, the reader should assume the defaults are being used in a question.
Please keep picking me up on things though, it wouldn't be The Daily CLAD if I didn't make an error at least once a week.
H was indicating the values were in Hexadecimal form. I usually use 0x to indicate hex.
