From 11:00 PM CST Friday, Apr 11th - 1:30 PM CST Saturday, Apr 12th, ni.com will undergo system upgrades that may result in temporary service interruption.
The Daily CLAD
Community Browser
Re: Initialisation of Feedback Nodes
SercoSteveB
The following VI was created, saved and then executed twice (the user presses the Run Arrow twice).  What is the value of Numeric Value Out following the second execution of the VI?
a) 8
b) 16
c) 32
d) 64
Comments
whitecr
Ans: A
A.Bernau
a
I think I am wrong. Because of the influence of "executed twice"
But then it should be 128?
I am confused I have to code it later ...
Ah, ok. Thank you for the detailed explanation crossrulz
nik35324
A
crossrulz
Knight of NI
Well, if it was ran twice in the same execution, you would get 128.  Therefore the answer must be A.
The important thing here is that the FB Nodes are initialized on first call.  So you run the VI once, that execution ends.  So the next time you run it, the First Call will be TRUE and the FB Nodes are reinitialized.
GCentral
LordNobady
A
Learning LabVIEW since January 2013
SercoSteveB
Good point, question text amended to clarify.
Mohammed_Atef
A
MrStevenUND
A
sathishp91
A
hemanth.wnp@gmail.com
A
ashwinilele
A
rsmrostov
A
SercoSteveB
Answer: A.  Nice one whitecr, Andreas23, nik35324, crossrulz, LordNobady, Mohammed_Atef, MrStevenUND, sathishp91, hemanth.wnp@gmail.com, ashwinilele & rsmrostov.
Here we are using Feedback Nodes that are initialised on First Call.
M.P.Bharghavi
Ans:A
8
