The Daily CLAD
Community Browser
回應: CLAD2017 - Output Data Structure
SercoSteveB
What is the structure of Data Out in the VI?
a) A Cluster containing 3 numeric values
b) An Array of numeric values
c) A Cluster containing an Array of numeric values
d) An Array of Clusters containing 3 numeric values
Comments
GladysToMeetYou
D
Vinay_Kumar_M_S
D
Technoliv
D
Karthiga
 Ans: Option D
Because, inputs to the "Add" node will be an array of cluster and a cluster. According to polymorphism, the output "Data Out" will be an array of cluster of three numeric values.
nik35324
D
crossrulz
Knight of NI
D
GCentral
Matt-A.
D.
qubirt
D
CataM
NI Employee (retired)
d)
Ellie90
d
VSReddy
Output is an array of clusters.
D
Sunil Reddy
SercoSteveB
Answer: D.  Nice one all.
MAX_2019
D
Pavel_NDC
how to build it? ADD func reply me an error...
Pavel
crossrulz
Knight of NI
If you delete the indicator, do you still have a broken wire?  You can right-click on the output and Create->Indicator.
GCentral
Pavel_NDC
My mistake, it is OK.
Thanks, Pavel
istan0227
D
