La fonction de suggestion automatique permet d'affiner rapidement votre recherche en suggérant des correspondances possibles au fur et à mesure de la frappe.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
In the help file for "Pick Line" (interesting function, I've never used it before), it says,
"multi-line string contains one or more substrings separated by linefeeds."
I read this to mean that the delimiter in this function is the Line Feed character (ASCII code 10, or \n), and not the Carriage Return character (ASCII code 13, or \r).
However, after playing with the code, it seems that EACH delimiter used by Steve (\r\n*, \n, and \r) results in a new line for "Pick Line" to read.
Am I making a mistake while code-tinkering? Is the documentation wrong? (Or perhaps the documentation isn't wrong, just misleading? By saying "linefeeds" instead of "Line Feed characters"?)
-joeorbob
*I'm on a Windows machine, so the End Of Line Constant for me is "\r\n".
Pour ajouter un commentaire ici, vous devez être inscrit. Si vous êtes déjà inscrit, connectez-vous. Dans le cas contraire, inscrivez-vous puis connectez-vous.
