The Daily CLAD
Community Browser
Waveform Graph Series: 4 of 5
SercoSteveB
Describe the data displayed on Waveform Graph #1 and Waveform Graph #2 following execution of the VI?
NOTE: Assume the Transpose Array option for both graphs is set to OFF (do not transpose).
a) Graph #1 contains 2 plots each with 4 data points, whereas Graph #2 has 4 plots each with 2 data points.
b) Graph #1 contains 4 plots each with 2 data points, whereas Graph #2 has 2 plots each with 4 data points.
c) The data displayed is the same for both graphs; each containing 2 plots each with 4 data points.
d) The data displayed is the same for both graphs; each containing 4 plots each with 2 data points.
Comments
