LabVIEW Interface for Arduino Blog
Community Browser
Labels
Re: interface LabVIEW with Arduino UNO
Hamoda
i opened LIFA_BASE.ino on Arduino 1.6.0 but it didnt compile and message occured !!
Arduino: 1.6.0 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
what should i do ??
Comments
hrh1818
LIFA_Base also does not compile with Arduino version 1.0.6.  But LIFA_Base will compile with Arduino version 1.0.4.  Hemce if you need to use LIFA you need to use an older version of the Arduino IDE.  Older version of the Arduino IDE can be found near the bottom of this web page.
<http://arduino.cc/en/Main/OldSoftwareReleases>
Or you could use LINX.
hrh212
