I need your help on Multiple Aquisition Data Sampling using Arduino. I am having the same problem as the following post;
https://decibel.ni.com/content/message/50853#50853
I need to collect 15 analogue measurments and send 5 digital output synchronously with a sample rate of 0.01 sec. What do you suchest me to do?
You mentioned one might be able to do that by "createing a custom command that reads x samples from the user specified pins"... could you please give an example of that?
I can use multiple arduinos if you think it will help.
Hesam
