LabVIEW Interface for Arduino Blog
Community Browser
Labels
PWM output High before vi starts
hgadm2
Dear all,
I am currently testing the LabView for Arduino toolkit.
I need to generate a 0-5V DC voltage out of a PWM channel to control the sensitivity of a photomultiplier.
This control voltage will generate a high voltage of 0-1250V at the photomultiplier tube circuit.
(I plan to use a 2-pole lowpass filter based on an LM358 OpAmp to smoothen the PWM signal)
I have so far just connected an LED (of course plus serial resistor) to the PWM output and can dim the LED with the PWM using a 0-255 control.
So far so good.
However, when I connect the LED to the PWM output it is fully lit already when the Arduino (UNO) is conncted to the PC, even though the vi is not yet running, so the lopass would propbably already supply a full 5V to the photomultiplier at that stage.
This is not good as a 5V output would switch the photomultipler to its full high voltage of 1250V instantly, whereas I would normally start much lower and increase hi voltage (= sensitivity) only as needed by the light levels.
As soon as I start the vi, the LED turns off and I can use the dial to adjust the brightness from zero to full, but the damage will be done to the photomultiplier already, because it receives a 5V control voltage from the Arduino even before the vi comes to play.
Why is the PMT output hi and not not zero before the vi starts???
What can I do to force a zero signal at the PWM output when the Arduino is connected to the PC but the vi to control the whole thing is not yet started?
Many thanks
Holger
Comments
