LabVIEW Shortcut Menu Plug-Ins
List of Community Shortcut Menu Plug-ins (Part 1)
The following is a list of community-contributed Shortcut Menu Plug-ins for LabVIEW.
No. Shortcut Menu Plug-in Author
Included in LabVIEW?
(if so, since which version)
Is one of Darren's Favourites? Is one of AQ's Favourites?
1 Ad-Hoc VI Scripting.llb  flarn2006 No No No
2 Adapt SubVI Inputs.llb Hooovahh No No No
3 Add Bookmark.llb Matt J No No No
4 Add SubVI Description.llb jyoung8711 No No No
5 Add Value Change Event.llb McQuillan No No No
6 Alphabetize Cluster Elements.llb Christopher R Field No No No
7 Alphabetize Event Structure.llb nanocyte No No No
8 Assign to Connector Pane.llb Felipe Pinheiro No No No
9 benchmark this code.llb and remove benchmark structure.llb smithd No No No
10 Bundle Swap.llb Wiebe@CARYA No No No
11 BundleMagic.llb littlesphaeroid No No No
12 Call Library Node Dynamic Path.llb Darren No No No
13 Change Mechanical Action from Diagram.llb Darren LabVIEW 2018 Yes No
14 Change Numeric Conversion Type.llb Darren No No No
15 Change Output Representation of a "Boolean Array to Number" TheQ No No No
16 Change To Bundle Or Unbundle.llb CharlotteN No No No
17 Change To Different LabVIEW Class.llb AristosQueue No No Yes
18 Clear Variant Data.llb Bob_Preis No No Yes
19 CloseReference.llb JW-JnJ No No No
20 Control default values.llb Yair Neeman No No No
21 Convert Color Box.llb Darren LabVIEW 2016 No Yes
22 Copy and Paste Font of text elements Floris Reinders No No No
23 Copy Delimited Data.llb Darren No Yes No
24 CopyAndPasteString.llb smithd No No No
25 Create Cluster Constant as Icon.llb jtagg No No No
26 Create Elements from your own palette.llb Lorenz Casper No No No
27 Create Event.llb Darren LabVIEW 2018 Yes Yes
28 Create Helpful Constants from Select Function.llb  McQuillan No No No
29 Create Icon from VI Name.llb Haobo Li No No No
30 Create In All Frames.llb AristosQueue No Yes No
31 Create IPES Border Node.llb Darren No No No
32 Create Scalar Constant.llb (from an array terminal) Bob_Preis No No No
33 Create SubVI from Selected Wires.llb Darren LabVIEW 2018 Yes Yes
34 Cut Copy Delete Items.llb AristosQueue No No No
35 Debugger Notepad.llb jtagg No No No
36 Document to Clipboard.llb JW-JnJ No No No
37 EasyConvert.llb JW-JnJ No No No
38 Edit A Set Value.llb / Edit A Map Value.llb AristosQueue No No No
39 Edit Label In Markup.llb AristosQueue No No No
40 Edit Symbols.llb (for Listbox and Tree controls) Hooovahh and Thoric No No No
41
Error Ring Search.llb Hooovahh No No No
42 Expand Cluster Constant.llb AristosQueue No Yes Yes
43 Explain Error on Nested Error Cluster.llb Darren and AristosQueue No No Yes
44 Find Case.llb jrayeske LabVIEW 2020 No No
45 Find Events.llb Wiebe@CARYA and Darren No Yes No
46 Find Next Frame Plug-Ins.llb DAD No No No
47 Find Wire Source.llb Darren No Yes Yes
48 For Loop - Generate.llb AristosQueue No No Yes
49 Free Label To Constant.llb AristosQueue No No Yes
50 Free Label To VI Description.llb  Petru_Tarabuta No No No
For plugins 51 to 100 see List of Community Shortcut Menu Plug-ins (Part 2). The list had to be separated into multiple parts because each post cannot exceed 50,000 characters.
For Darren and AQ: Feel free to make modifications or improvements.
For everyone: Please let me know if you spot a mistake, or if you would like a new entry to be added to the table.
Comments
flarn2006
Member
Member
on
Petru_Tarabuta
Active Participant Active Participant
Active Participant
on
Hi flarn,
I added your plugin to the list.
Petru
flarn2006
Member
Member
on
Thanks 🙂 Hope people find it useful.
Contributors
