LabVIEW Shortcut Menu Plug-Ins
Change To Bundle Or Unbundle.llb
Author: CharlotteN (NI)
Changes a Bundle or Bundle By Name to the Unbundle function of the appropriate type and vice versa. So selecting this option...
..... produces this:
It can work on a selection of bundlers or unbundlers but not a mixture of both. All inputs/outputs in a Named Bundler/Unbundler will revert to the first element in the cluster. This is something I would like to change if I find time.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Comments
iannicholson
Member
Member
on
Just curious if you had time to fix the naming issue?
CharlotteN
NI Employee (retired)
on
Hi Ian, it has been a long time since I looked at this plug-in I must admit. What issue is happening with regards to naming?
felipe.foz
Member
Member
on
Hi Charlotte,
Just tried this plugin today and it didn't work first time.
I opened the LLB and each of the VIs, and it looks like some path reference issue was bugging the plugin.
After re-saving all VIs, then it worked.
Just to inform, I don't really know if it just happened to me.
Cheers,
Felipe Pinheiro Silva
Follow my blog for LV content!
Contributors
