LabVIEW Shortcut Menu Plug-Ins
Call Library Node Dynamic Path.llb
Author: Darren (NI)
This plugin adds a 'Specify Path on Diagram' right-click menu item to the Call Library Function Node:
This menu item performs the same function as the 'Specify path on diagram' checkbox in the Call Library Function dialog box. The menu item appears when one or more Call Library Function Nodes are in the right-click selection.
Attachment is saved in LabVIEW 2015. For install instructions, go here.
Contributors
