Takes an event structure and rearrange the frames so that they appear in alphabetic order
Description
After discovering that the existing sort function doesn't work, I made a shortcut menu plug-in to rearrange the frames on an event structure so the appear in alphabetic order
I was seeing similar issues. I have the "separate compiled code" flag checked in that VI. I'm wondering if there's a LabVIEW bug where it doesn't realize it needs to recompile for the newer version.
Some things that might help:
Uncheck the separate flag on the VIs and controls in the llb
Try a mass recompile on the llb folder
Clear object cache
I think the plugins are loaded when you launch the development environment so you'll have to close out and reopen LabVIEW
