LabVIEW Shortcut Menu Plug-Ins
Convert Color Box.llb
Author: Darren (NI)
Note: This plugin ships with LabVIEW 2016 and later. You only need to download and install the plugin from this page if you are using LabVIEW 2015.
Convert Color Box (inspired by this Idea Exchange entry)
Convert a U32 numeric to a color box, or convert a color box to a U32 numeric. In the case of going from color box to numeric, formats the numeric in hex, shows the radix, and sets a fixed character width of 6 (to make it easy to see the RGB values). This plugin works on U32/color box numeric controls, indicators, control/indicator terminals, and constants. It also works on multi-select.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Contributors
