LabVIEW Shortcut Menu Plug-Ins
Create In All Frames.llb
Author: AristosQueue (NI)
Right-click on an unwired inside terminal of a tunnel on a case or event structure. Allows you to create a constant in every frame that is currently unwired. Vastly simplifies the data entry when you have to type in a different constant value in every frame.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Contributors
