Author: Tom McQuillan
This plugin is similar to the menu to add event support in LV2018 - but it was suggested that I post this on here anyway. For me, this is a more convenient way of creating value change events as they are the events I/we make most often. This tool has fewer nested right-click menu items, and you can create events for multiple controls at once.
Also, I didn't realise 2018 has a similar tool when I initially wrote this. When it was pointed out to me, I did copy and paste the event-checking section of code.
Original Linkedin post to gauge community feedback: https://www.linkedin.com/feed/update/urn:li:activity:6516965533194293248/
Attachment is saved in LabVIEW 2015. For install instructions, go here.
Thanks for sharing 🙂
Very handy plugin. I noticed that if you try using this on a control nested within a cluster you get some unexpected effects. In that case I would suggest not moving the control in question into the event structure?
