Author: jtagg (NI)
This plugin adds a menu entry to create cluster constants directly in icon form. This is especially useful for large nested clusters that take a lot of space and deform your structures before you have a chance to convert them to icons.
Works on:
What it does not work on:
Before:
After:
Notes:
Attachement is saved in LabVIEW 2015. For install instructions, go here.
This should be a built-in feature to LabVIEW. And this is why I don't use auto-grow on structures.
Agreed! I think custom right click menus is a way for us to get some of the features we always wanted.
I haven't tried the plugin, but creating the expanded constant and replacing it by an icon WITHOUT repositioning it WILL result in hidden icons in small structures.
I don't see any icons get hidden. When the structure is really small, it tends to appear over the VI it is created from. I tried with and without auto-grow active and the result was the same.
I try this feature but for my part, I used sometimes big cluster that can't be shown in a screen and my problem is when I create the constant in a case structure, the size of it increase.
Should be perfect to find a way to create a constant of a cluster without the need to create first the constant then change it to an icon.
