Author: Darren (NI)
Note: This plugin is included in LabVIEW 2018 and later. You only need to download and install it from here if you are using LabVIEW 2017 or previous.
Right-click the terminal of a Boolean control and change the mechanical action of that Boolean.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Hi,Darren , why my shortcut menu is defferent with yours? I have install the “Change Mechanical...” and Run "refresh Menus"
I have solved it , your shortcut menu is in the Back Panel
