Author: haobo.li
Overview
A LabVIEW 2015 PopupMenus Plugin - Create Icon from VI Name
Description
From LabVIEW 2012 and later, if you set "Control Panel\Clock, Language, and Region\Region\Formats" as "Chinese(Simplified, China)", fonts display in LabVIEW will be broken. Such as "small Fonts" in Icon Editor won't display Clearly. To work around this bug or "feature" ,you can just increase fonts bigger than 12 points, or change formats back to "English(US)".
But Some Application as IBM Notes Chinese Version require Formats set to "Chinese" to work well. So I write a LabVIEW plugin called "Create Icon from VI Name".
How to work:
Warning: This Plugin will try to SAVE the SubVI you select!
Hope this Plugin would be any help.
Any suggest would be welcome ,fell free to contact me at Mail@haobo.li
LabVIEW 2012之后的版本一直有在中文系统里,字体显示模糊的bug,而且看起来是准备当作feature流传下去了。
在创建图标时,图标编辑器可以设置成12号字然后正好输四个汉字就可以规避这个问题。不过输入英文就不太方便了,因为只能显示大约6个字符。
所以我做了一个LabVIEW 2015的右键插件,可以从文件名自动产生图标,最多显示5行7列35个英文字符或者数字。
使用方法:
注意:这个插件会尝试保存这个子VI。
欢迎提出宝贵意见,我的邮箱:mail@haobo.li
Source Code
https://github.com/lhb5883/LabVIEW/tree/master/Create%20Icon%20from%20VI%20Name
Requirements
Software
LabVIEW 2015 and later
Hardware
Additional Images or Video
Before:
After:
Updated In 2015/08/12
Add Create Icon Tools for LabVIEW 2009 and later.
How to work:
增加了工具栏版本,LabVIEW 2009以后均可使用:
CLA & CLED
There is a community specifically for these here: https://decibel.ni.com/content/groups/labview-shortcut-menu-plug-ins
You should post this there.
Why is this a right-click on the subVI node? Why didn't you write this tool and put it in the Tools menu as an edit to the VI you're currently working on? Having popup menu items to edit the VI that you're calling is very odd behavior -- popup menu items should edit the item you're popping up on, not its related thing.
That's sounds a good idea! Thanks!
I will Post In there later
Finished!
CLA & CLED
That's a good idea!
In this way , this Plugin could work for previous Version LabVIEW.
In LabVIEW 2015,This Plugin will create icons for Multiple SubVIs once you select, it should be a little convenient in my opinion .
CLA & CLED
I didn't look at the code, but looking at the images, I see that you have 5 rows of text, which I assume means you're generating the text yourself. Would it be possible to use the icon editor API to set the text in the same way that the icon editor does, so that people can later go into the editor and change it, or will that not work with the font limitations you talk about and that should be a separate plugin?
AQ, I agree that invoking this on a subVI is weird (although I understand the multiple-subVIs at once arguments), but putting it in the tools menu makes it less accessible. It would be nice if this could be a right click on the icon, but the menu doesn't let us do that. With the JKI RCF, there was a loose convention where actions on VI are added to the menu if the menu is invoked on the FP with no objects selected, but I'm not sure if the current API allows that. Maybe if it does, both methods could be used to access the plugin.
Yes, I generate the Text myself to aviod the fonts issue.You can see the detail in my github source code:I use Fonts.vi to import bmp to LabVIEW pixmap data, then use it to Convert Strings to pixmapdata.
It's GREAT IDEA to Set the New Icon to a new Icon Layer.Thank Very Much! I will work on the icon editor API.
CLA & CLED
AQ you said something that I'd like more of an opinion on
I don't see this as being that odd of a thing to do. Are you saying that you don't suggest making plugins, that modify a subVI that is called? One application I'm sorta in the middle of would allows to edit a subVI based on a right click menu, or optionally create a new copy of that VI to be saved somewhere, and then edit that copy.
Hopefully I'll have an example of my code and show how I can see a use for this soon.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
> that copy.
Various usability guidelines exist to make sure that right-click menus have the scope that a user expects them to have. In most cases, we interpret this for LabVIEW as meaning the right-click menus should only modify the thing you clicked on, not modify a thing referenced by the thing you clicked on. A right click can open the thing that is referenced so that you can modify it there, but not make the edit directly.
A right-click that says "clone the VI and replace THIS CALL to the VI with the new clone" would be an approrpriate use of the right click because you aren't changing any of the other call locations for this VI -- it is a localized edit. A right-click that said "make this subVI reentrant" would be an inappropriate use of the right click because it affects all callers everywhere. Even if you know that the scope is all callers everywhere, it is reasonable for a user to expect that the popup somehow makes just this one call reentrant.
Yours, Brian, sounds like a gray area. lhb5883's plug-in is clearly in the wrong. It places functionality for editing the VI at the call site instead of within the VI being edited.
Now, having said that, if you want to write such a plug-in, go for it -- it's your environment and you know how it works. But that's not the same as having a good plug-in to promote to the community. If this were proposed to ship with LV, I'd nix it on usability grounds.
Thanks for the explanation, as you probably already know (because I'm guessing you get emails when replies are in this community) I was referencing this plugin. I did wonder how things like undo would be handled if the code to be undone, was code generated not from that VI. Admitedly I never tested that.
Oh and this plugin is a little harmless right? I mean I realize there could be issues but editing an icon? It isn't editing the code in the VI that is called in multiple places. I agree on principal, and I never expect to see this shipped with LabVIEW, but I'm not sure I care too much.
Well, kind of. You point out "undo" -- even if the plug-in does its own transaction management (and I hope that it is doing so), if a user picks this menu item, edits the icon, and then decides they don't like the new icon, hitting ctrl+z will undo... something unrelated on their diagram! But it won't undo the icon change. That's fairly bad behavior. It isn't a transaction on the local document, so you have to go to the other document to undo it.
Thanks for your advice!
It seems that I shouldn't to auto save the SubVI. Lost VI undo ability is worse than lost of the auto creatable Icons. It annoy my self sometimes
If I Open the SubVI first , then change the VI icon would be better? Should I add dialog to Confirm It?It seems that It is suit to create a “icon manager” in Tools Menu instead a right click menu,Isn't it?I totally agree with you.
I will try this possibility later,it is a lot work to do with this plugin.
CLA & CLED
It would definitely make it _better_ but still not good, in my opinion. As I said, I would not put it in the right-click menus at all. I would just put this in the Tools menu of the VI to edit that VI. So the sequence is "double click on the subVI to open it, then go to Tools >> Autoset Icon Using Name" or something like that.
Your "Execute" VI is basically the exact VI that would be needed in the Tools menu, except you have to get the VI refnum using the Active VI property (I think that's its name... you'll have to double check) instead of having it passed in to you.
AristosQueue wrote:
...you have to get the VI refnum using the Active VI property (I think that's its name... you'll have to double check) instead of having it passed in to you.
For any utility VI launched from the Tools menu, make sure you call this subVI as the first thing on your diagram:
vi.lib\VIServer\Menu Launch VI Information.vi
It will give you the Application Instance and VI Name of the VI from which the Tools menu VI was launched.
