This is all of the plug-ins that I have personally chosen to keep for my own development in LabVIEW. This is a subset of the total plug-ins available on this community site. It includes some written by NI devs and some written by our customers.
This .zip makes it easy to just grab these plug-ins -- just unzip them into the directory and you're done. The downside is you might not get the latest edits that the authors have made to their plug-ins. And you might want some of the plug-ins that I don't like. Darren and I, for example, have different ways that we want our personal environment to work, so I leave out some of the ones I know he would include.
I will update this list (and the .zip file) over time. At the moment, this zip includes the following:
Change To Different LabVIEW Class.llb
Clear Variant Data.llb
Convert Color Box.llb
Create Event.llb
Create SubVI from Selected Wires.llb
Expand Cluster Constant.llb
Explain Error on Nested Error Cluster.llb
Find Wire Source.llb
For Loop - Generate.llb
Free Label To Constant.llb
Insert Build Array.llb
LabVIEW Class And Cluster Unbundle Bundle With IPE.llb
LabVIEW Class And Cluster Wire Insert IPE.llb
Lookup All Shortcut Menu Tags And Types.llb
NI.Wire Drill.llb
Popout Breakpoint Menus.llb
Show All Hidden Cluster Elements.llb
Text Properties.llb
Wire Multiple Items to Bundler.llb
A nice touch would be to have links to the respective entries on this website in the list above...![]()
NI Wire Drill?
The wire drill plugin can be found here: https://decibel.ni.com/content/docs/DOC-43216
Not contributing anything new... just a hyper-linked version of the plugins list above. Hope the URLs persist.
Change To Different LabVIEW Class.llb - NI Community
Clear Variant Data.llb - NI Community
Convert Color Box.llb - NI Community
Create Event.llb - NI Community
Create SubVI from Selected Wires.llb - NI Community
Expand Cluster Constant.llb - NI Community
Explain Error on Nested Error Cluster.llb - NI Community
Find Wire Source.llb - NI Community
For Loop - Generate.llb (for FPGA code generation) - NI Community
Free Label To Constant.llb - NI Community
Insert Build Array.llb (for broken wires) - NI Community
LabVIEW Class And Cluster Unbundle Bundle With IPE.llb - NI Community
LabVIEW Class And Cluster Wire Insert IPE.llb - NI Community
Lookup All Shortcut Menu Tags And Types.llb (not found?)
NI.Wire.Drill.llb (for wiring from a caller deep into a VI hierarchy) - NI Community
Popout Breakpoint Menus.llb (move bkpt menus to top level) - NI Community
Show All Hidden Cluster Elements.llb - NI Community
This one ships with LabVIEW: [LabVIEW 20xx]\resource\plugins\PopupMenus\support\Lookup All Shortcut Menu Tags And Types.llb
You have to copy it into one of the plugin folders if you want to use it.
AQ's favourite shortcut menus and Darren's favourite shortcut menus can also be identified by looking at the "Is one of AQ's Favourites?" and "Is one of Darren's Favourites?" columns in List of Community Shortcut Menu Plug-ins (Part 1) and List of Community Shortcut Menu Plug-ins (Part 2).
