LabVIEW Shortcut Menu Plug-Ins
LabVIEW Class And Cluster Unbundle Bundle With IPE.llb
Author: AristosQueue (NI)
This plug-in makes it easy to an an In Place Element structure for unbundling/rebundling clusters and LabVIEW classes. You right click on a terminal of cluster or class type. The new menu item is added under the Create menu. For LabVIEW classes, the option only appears when you are in a member VI of the class (because non-member VIs are not allowed to unbundle class data).
The terminal does not have to be wired but it can be. This does a create on a branch. It does not insert the IPE into the wire.
If you like this, you may also want this related plug-in which does the same thing but works on wires and does Insert behavior.
Before:
After:
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Comments
vishots.com
Member
Member
on
Is there a reason why this is inconveniently on a branch instead of the more convenient insert?
AristosQueue (NI)
NI Employee (retired)
on
I have needed both models, but I didn't want to add some sort of dialog to pick which one. It seemed to me to be easier to rewire for the insert case when I needed it than to unwire for the branch case when I needed that.
You think I should default the other way?
Beutlich
Member
Member
on
Could you comment on the use cases/distinction between the two? I would've defaulted pass through also, because it ensures whatever you connect to the wire out is the same data space, whereas connecting to the wire before may or may not be a copy of the class data, and knowing if there is a copy or not is hard to guess from just the wiring (and I probably care about data spaces since I'm using the IPE and not just a bundle/unbundle).
- Regards,
Beutlich
AristosQueue (NI)
on
When I fork a class wire, I intend to make a copy. Whether or not LV actually makes a copy is a matter for it to decide inside the compiler. I don't care when the copy gets made, so long as from my point of view, it happens at the fork.
The fact that I am forking means it is my intention to modify a separate copy of the object. This occurs when I am going to modify some of the fields but I need to be able to support Undo or transaction rollback -- where I'll have to put the original object back into play later if the transaction fails or the user chooses Undo. I may still have reason to use the IPE structure for this separate modification, especially if the modification is incrementing some existing field or something like that.
smithd
Active Participant
Active Participant
on
I would agree with the others that the default should be inline. I've done what you're suggesting with a transaction-like behavior, but rarely do I do that at the same level as the IPE. Usually the IPE would be within a subVI, while the calling code is responsible for the transaction.
AristosQueue (NI)
on
I do both with equal regularity, but I'm happy to adjust the behavior for this plug-in if there's a clear bias across the wider user base. I'll try to get it done this afternoon.
AristosQueue (NI)
on
Had an idea...
what if I leave this plug-in unchanged -- you popup on a terminal, you get "Create" behavior, which adds a branch (just like if you had done Create Indicator).
But then I create a second plug-in that works on wires and goes into the Insert menu. "Insert Bundle\Unbundle In-place Element Structure".
Would that be a good way to split the difference?
Craig_
on
That sounds like a solution that services both needs!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
smithd
Active Participant
Active Participant
on
Works for me, and then you'll have a better measurement of what people prefer as well.
AristosQueue (NI)
on
I posted the new inserting plug-in here:
https://decibel.ni.com/content/docs/DOC-43649
Contributors
