LabVIEW Shortcut Menu Plug-Ins
Popout Breakpoint Menus.llb (move bkpt menus to top level)
Author: AristosQueue (NI)
This download is not so much a plug-in as a plug-out. It will reposition all of the Breakpoint menu items to be top-level menu items instead of being in a pull-right menu.
This download is also special -- you install the same .llb file into BOTH the edit-time and the run-time directories so that both the edit-time and run-time menus are modified.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Contributors
