LabVIEW Shortcut Menu Plug-Ins
Insert Build Array.llb (for broken wires)
Author: Trevor_C (NI)
When you have a broken wire that is a scalar connected to an array of the scalar's type, this menu item lets you quickly insert a Build Array node. This plugin does not work with multi-select.
This plug-in addresses a bug in LabVIEW. There is a built-in menu item for "Insert Build Array" on such broken wires, but it appears inconsistently. The popup menu item appears consistently in all cases where it applies.
Contributors
