User | Kudos |
1 | |
1 | |
1 | |
1 | |
1 |
We source control testexec.ini, becuase I want to replicate the custom path information, which is stored in testexec.ini, among our other stations. But, whenever I start teststand, it tries to write to testexec.ini for some reason, and I get the "can't write to testexec.ini" message because this file is set to read only when checked in (which in our case is most of the time). I have become so accustomed to clicking this message that I dont' even think about it.
But, I do have a request to the developers. Please store path information (paths configured under configure/search directories) to a file all by itself, or to a file that does not share so much other information that testexec.ini stores (which is a lot). I notice there is a file called teststandperistedoptions.opt, that appeared around TS2010, that perhaps a lot of the testexec.ini stored stuff can be migrated to? That way I won't get this message every time I start teststand.
At least one other person has had a similar issue.
http://forums.ni.com/t5/NI-TestStand/TestExec-ini-version-control/td-p/1048091
David Jenkinson
