Using CVI I can't find an easy way of moving inside a source code file.
Based on my experience with other C editors, I suggest these 3 little features that I think are really useful:
- a shortcut to jump to the beginning of previous function in the same source file (CTRL + PGUP, for example)
- a shortcut to jump to the beginning of next function in the same source file (CTRL + PGDWN, for example)
- the current function where the caret is, displayed in the toolbar. It will be nice if you use a combo so that the user can jump to a different function with a simple mouse click (see attachment)
I have thease features in an open source C/C++ editor (Code::Blocks) I use for other projects, and I think they're really useful to reduce the coding time.
When you have large source files with a lot of functions, with CVI is't difficult to easily see where you are inside the file; moreover it's quite common scrolling the file jumping from a function to another.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
