From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
LabWindows/CVI Idea Exchange
vix
Go to Next/Previous function in source files
Status: Completed
Introduced in LabWindows/CVI 2013
Using CVI I can't find an easy way of moving inside a source code file.
Based on my experience with other C editors, I suggest these 3 little features that I think are really useful:
  • a shortcut to jump to the beginning of previous function in the same source file (CTRL + PGUP, for example)
  • a shortcut to jump to the beginning of next function in the same source file (CTRL + PGDWN, for example)
  • the current function where the caret is, displayed in the toolbar. It will be nice if you use a combo so that the user can jump to a different function with a simple mouse click (see attachment)
I have thease features in an open source C/C++ editor (Code::Blocks) I use for other projects, and I think they're really useful to reduce the coding time.
When you have large source files with a lot of functions, with CVI is't difficult to easily see where you are inside the file; moreover it's quite common scrolling the file jumping from a function to another.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
8 Comments
Adri_K.
NI Employee (retired)
Status changed to: Under Consideration
Adri Kruger
LabVIEW Product Marketing
Adri_K.
Status changed to: In Development
Adri Kruger
Laura F.
Status changed to: New
prior status deleted, setting to default
LuisG
Ralf Hohendorf
Good idea.
Should be implemented as fast as possible.
JonathanN
Status changed to: In Beta
Jonathan N.
JonathanN
Jonathan N.
JonathanN
Status changed to: Completed
Jonathan N.
