| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 5 | |
| 4 |
How often did I have to correct this bug in my code:
The coding idea is "if array not empty, do ...." and so I wire the output of "Empty Array?" to a case structure and start coding. Dependent on the time of the day however I forget that the dropped case structure is on "True" and that I have to put my code into "False". The same happens with "Empty String .." and and "Not a Number / Path / Refnum ?"
Couldn't we have the negated functions as well, accessible by "right click", as we have them in the compound arithmetic?
Furthermore, I wish the negated versions to be default.
