User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
Suggestion: Correct the symbol of the "not" primitive function by removing the invert dot on the input node in the icon.
currently: source: http://zone.ni.com/reference/en-XX/help/371361H-01/glang/not/
That means in exact words of the LabVIEW design the following: negate and negate; first negate due to the invert dot at the input, then negate again due to the "not" function.
suggestion: That means negate (only once). See also http://en.wikipedia.org/wiki/Negation
IMHO, unless this is corrected, other ideas have no chance to be implemented consistently, such as: Negate input on boolean functions
Thank you for reading!
