DIAdem Idea Exchange
JuliaDawkins
Allow more than 5 workers for DIAdem 2018+
Status: Declined
Hello Julia,
Thank you for your suggestion. Because we had technical problems in some cases with more than 5 Workers in the past, we decided not the extend the number of Workers.
Greetings
Walter
Since DIAdem 2018, the number of 5 worker objects has been restricted to 5. This is a difficult limitation for those who are enjoying the use of unlimited worker objects in earlier versions of DIAdem, and do not want to purchase the Analysis Server.
2 Comments
Pesmith8
Would like to propose that NI allow versions of DIAdem to be sold that have higher number of worker objects allowed.
It is far easier to use a Local DIAdem in many instances on a Large machine with more than 8 cores to do processing than to use Analysis Server.
Especially if use modern 32 to 64 core hardware.
Paul
Walter_Rick
NI Employee (retired)
Status changed to: Declined
Hello Julia,
Greetings
Walter
