Vision Idea Exchange
varga.sm
Calculator step - Compute Results, Expandable Window
Status: Completed
Long names may get cut off in Measurement window, allow for a separate window, like the View Measurements dialog box, to fully display names and values with resizeable fields, instead of just relying on tool tips
2 Comments
Brad
Status changed to: In Development
In VBAI 2018, the table of results is now a tree so all the array elements can be viewed. The columns can also be resized, but we did not make the UI pop out, so it is still limited by the size of the default step area.
Hope the updates help, but let us know if this still does not address your needs.
Thanks for the feedback!
Brad
Status changed to: Completed
