it can be a simple and stupid question, but I don’t get why, when I define a container as a parameter of a sequence called in the main sequence. That parameter can’ be expanded to fill the different field with the variables that I need. I created also custom type variable for trying to achieve this aim but nothing. I thing that passing a container as parameter can be helpful in particular when you need to pass a lot of variables regarding the same “object".
Best Regards,
Zuc
