User | Kudos |
1 | |
1 | |
1 | |
1 | |
1 |
When TestStand launches, it determines the active LabVIEW version and copies the TestStand API VIs into <LabVIEW>\vi.lib\AddOns if not already present. (SOURCE)
I suggest there should be an additional step here and TestStand should call that LabVIEW version to mass compile these VIs.
Currently, the VI version remains unchanged which means when you open a LabVIEW code module which uses these, you'll sometimes find you have a 'dirty dot' due to unsaved changes because of the recompilation. It also means that you wouldn't be able to run a sequence using the LabVIEW Run-Time Engine until you've switched to Development and converted the VIs.
This is a minor annoyance but it would be nice if TestStand could cut out the additional version conversion step.
I do wonder whether the transfer of the TestStand API VIs into the vi.lib could actually occur when LabVIEW is installed if a TestStand installation is detected. Perhaps this might be relevant for other addons which existing LabVIEW installations have.
