NI TestStand Idea Exchange
Jick
Shortcut key for MainSequence run
Status: New
Many times I need to run the MainSequence after a change somewhere in a subsequence. Because there is no shortcut key for that action (First go to the MainSequence then Execute->Run MainSequence) it is pretty time consuming. It would be nice to have that shortcut key in TestStand.
Best Regards,
Jick
4 Comments
RayFarmer
Trusted Enthusiast
Maybe it could be explanded to include all menu items with the ability to change / add. Maybe held in a new cfg file that you would beable to include as part of the deployment.
Regards
Ray Farmer
AllenP
NI Employee (retired)
You can do this in 4.0 or higher.  Although it would run the current sequence, not MainSequence.  That may be good enough for you.
Right-click the toolbars and choose Customize.  Click the "Keyboard..." button in the bottom right.  In the Execute category, you'll see an "Run MainSequence" or "Run <SequenceName>" Command in the listbox on the right.  You can specify the shortcut in the combobox below.
This command will only execute whatever sequence is active, so if you select a different sequence in the same file, that one would become active.
Jick
Thanks, it helps but this is only part of the trick. There might be hundred sequences on the list and the most of the time goes when I scan the sequence list and go to MainSequence (or some other). Is it possible to add a shortcut key for "go to the sequenceX and run it" ?
dug9000
You could make a process model entry point that executes MainSequence in the client file and does nothing else. If you make it the first or second execution entry point it will have a hotkey by default or you can assign a different one if you don't like the default hotkeys for the first two entry points.
Hope this helps,
-Doug
