User | Kudos |
1 | |
1 | |
1 | |
1 | |
1 |
The Update VI Calls tool only works on sequence files right now. I'd like it to also work on Step Types in type palettes.
Here's the situation where it would be useful for me: I'm working on a set of custom step types for a customer, which use VIs as Edit-Substeps and Post-Substeps. Some of these VIs are shared between multiple step types.
The issue that I'm having is that if a customer requests a change to one of these shared VIs (for instance, to add another input or output), then I have to go through and manually update all of the substeps in all of the referencing step types. I've already had a situation where I missed an update of an edit substep. This didn't show up in our automated testing, because it is only run at edit time, but caused an error for the customer which they didn't know how to interpret. Our testing process now has to include manual opening of every single edit substep to make sure they all still work before every release.
As part of my validation before a release to the customer, I run the Update VI Calls tool to make sure that there are no broken VIs in the sequence files I'm shipping. The Update VI calls tool already makes sure that I've updated any step modules, but it doesn't catch if I've forgotten to update a Step Type's substeps.
And yes, I know, I could write my own tool to traverse a type palette and do the updating myself, but I'd like to see this integrated into the existing tool.
I'm declining this idea due to limited support from the community.
