Currently, there is no unambiguous solution for passing empty Array of X (where X is a different type than 64-bit Floating Point) as a sequence parameter. If we use {}
it is assumed to be of type 64-bit Floating Point. To have an empty Array of Strings we can use ambigues Split("","")
. I have no idea how to pass e.g. empty Array of Signed 64-bit Integer without creating empty variables.
It would useful to have Empty Array Literals of a particular type e.g.:
- default
{}i64
- for Signed 64-bit Integer
{}ui64
- for Unsigned 64-bit Integer
{}s
- for String
{}b
- for Boolean
{}r
- for Object Reference
{}c
- for Container
{}TYPE_NAME
- for type definition where TYPE_NAME
is type definition name; e.g. Path.
