User | Kudos |
1 | |
1 | |
1 | |
1 | |
1 |
It would be helpful to be able to provide a regular expression (like Labview Match Pattern) as a string value test limit. We often look for a pattern of data within a string rather than a constant.
Maybe also a regular expression function within the built in functions within TestStand expressions would be a help also. This could provide more flexibility if a user needs it. For example adding option to gain match position, and match length as well as give the option to search in reverse and ignore case.
This is available in TestStand 2020
