When I use the function "CopyTreeItem", the item is copied, but the value (behind the item is automatically increased or changed). Because the item might be used several times and the item is identified by its value, it is necessary, that the value behind the item is NOT changed. Please don't change the value of the item, when it is copied or please add a parameter, which handles the changing of the value (e.g VAL_DONT_CHANGE, VAL_LAST etc.).
