While developing code, having correct indentations is very helping in making sure you have all the right brackets and to see where your structures are nested easily. Sometimes, whether by copying and pasting or just rapidly getting out a section of code, a whole segment might have incorrect indentation, which is tedious to correct.
This is where an auto indent tool could be a big time saver. From somewhere like the Edit menu, where similar functionality is located in other development environments, you could select Format Selection to do a highlighted section or Format File to do the whole file. Then, CVI can format the tabs for you:
Although this is a simple example, auto indent becomes even more useful when you have multiple nested structures and decide, for instance, to add or remove another nested loop.
