If the label area is fixed size (i.e. option "Size to text" disabled) and is higher than the font height, it would be useful to have an attribute to set the text vertical alignment:
to the top
centered
to the bottom
Now the text can be justified only horizontally (left justified, centered, right justified)
Vix ------------------------------------------- In claris non fit interpretatio
------------------------------------------- Using LV from 7 Using LW/CVI from 6.0
