Using SetTableCellRangeVals to update several thousands table cells is very effective.(better than using ATTR_CTRL_VAL)
I miss similar function for set atribute values in the same way. In example:i need to set text to be bold or set background color for each table cell separately.
Ithik that usability of SetTableCellRangeVals will be better if SetTableCellRangeAttributes will be avivaible because there will be the same program approach/logic for values and attributes,instead of mixing multiple cell vallue update and one by one cell attribute update.
