 vix
			 on
		05-13-2011
		06:59 AM
			3 Comments (3 New)
			vix
			 on
		05-13-2011
		06:59 AM
			3 Comments (3 New)
		A tree control can be used to implement radio button controls;
in this situation you can't completely dim one of the items (so that it is grayed and the user immediately sees it is inactive) because the function SetTreeItemAttribute() doesn't allow ATTR_DIMMED attribute.
You can dim the item label using SetTreeCellAttribute(), but the check box stays active (see this discussion).
The EVENT_MARK_STATE_CHANGE can be swallowed, but the check box has the aspect of an active check box, even if nothing happens when you click over it.
I suggest to add the attribute ATTR_DIMMED to SetTreeItemAttribute() so that the whole item can be dimmed (its check box too)
