How To: display a message during for loop, with no user input necessary
Hi jmcbee, I only have labview 8.5 installed, could you please resave in that version?  I have to get 8.6 installed by our IS people......
thanks
Darren
jmcbee wrote:
Take a look at the attached VI's.  They will display a popup busy display with a programmable title.  The start and stop busy signal is sent using an Action Engine.  In you code you would remove the wait ms timer with error function and replace that with your 1 iteration for loop.  Let me know if you have any questions.
Message 11 of 15
(1,788 Views)
Accepted by DSRTM
Here you go.  Take a look at the Example.vi
Message 12 of 15
(1,782 Views)
Like I said, I'm new to LV Smiley Tongue
it works nicely when I copy my For Loop into your code, but not when I put your code into my VI.  I'll check it out and report back.  Thanks for the help so far, I really appreciate it.
Darren
Message 13 of 15
(1,761 Views)
Allright!  Done, works and seems to perform nicely.  Thanks everyone for the input.  Hopefully one day I can be the solution, not the question in this forum.
I have more Q's I'll start another thread when I get to it......has to do with saving files and error proofing.
Thanks again jmcbee.
Darren
Message 14 of 15
(1,757 Views)
DSRTM wrote:
...  Hopefully one day I can be the solution, not the question in this forum.
Darren
"From your post to God's ears"
We can always tolerate more help.
Ben
Message 15 of 15
(1,745 Views)
