Get Ascii code of a string
Hello to everybody,
I need to get the ascii code of a character, and i don't find the appropiate function to do it.
For example, i receive a string like this one: "6T8OP X" --> and i want to transform it to this: 54 84 56 79 80 32 88
Note: I'm using Labview 8.2
Much thanks to everyone!
Much thanks for your time and dedication!
(9,235 Views)
Accepted by topic author Output
Hi Output,
use the "string to byte array" function.
Mike
(9,228 Views)
OK Mike Thanks!
(9,221 Views)
Dear Output,
Please mark MikeS81 post as solution to your problem, so that other people looking for same kind of information will get more benefitted by this. You can do this by clicking on "Options" menu located at the top right corner of MikeS81 post and select "Solution". Hope you understand.
Also give some kudos to MikeS81 if you appreciate his help.
Mathan
(9,197 Views)
