Configure IVI Logical Name to use different Driver Session programmatically
Is it possible to change the Driver Session associated with an IVI Logical Name in Labview ?
thanks,
Gary.
(2,975 Views)
Hi Gary,
Unfortunately there is no function in LabVIEW that does any IVI setup.  All of the configurations for your driver sessions and logical names need to be set in MAX, and saved.  So while you can change the driver session a logical name uses, you can only do this through MAX.
Kind regards,
Sheela Sujeeun
National Instruments UK
(2,923 Views)
