Convert a text file to a.CSV
How do I convert a text file to a.CSV file
Message 1 of 13
(3,283 Views)
A CSV file is just plain text file with the convention that rows are separated by linebreaks and columns (typically) separated by commas.
What is the structure of your text file and what is the purpose of all this?
Message 2 of 13
(3,265 Views)
It's just the tab delimited measurement data file
Message 3 of 13
(3,259 Views)
Accepted by topic author LED47
I realize I just have to call it up in Excel, I was open you could give me just the extra bit where I would set it as a CSV file and save it
Message 4 of 13
(3,241 Views)
All you need to do is read it as a string, replace all tabs with commas, then save it again.
Of course excel has no problem also reading tab delimited files directly. I still don't see the purpose of all this. Using a comma as column delimiter could get problematic if you share it with someone in a location where the decimal delimiter is also a comma.
Message 5 of 13
(3,211 Views)
It could also be a problem if you actually need a comma in a string value.
I'm with Altenbach. If all you need is something that can easily be opened by Excel, a tab delimited text file works just fine. I do it all the time.
Message 6 of 13
(3,201 Views)
And also, I've had people asking for CSV files, when they meant TAB-delimited. So make sure you have the requirements of the assignment correct before doing unnecessary work.
Certified LabVIEW Architect
Message 7 of 13
(3,173 Views)
Okay thank you very much to everyone I think I understand now
Message 8 of 13
(3,160 Views)
My intention with the following:
Open a text file as a CSV:
Then save the CSV
Result opens in memory as a CSV... Actual saved file is not in the CSV format.
Message 9 of 13
(3,126 Views)
Did you not like the solutions you already got?
Message 10 of 13
(3,108 Views)
