Convert a text file to a.CSV
How do I convert a text file to a.CSV file
Message 1 of 13
(3,357 Views)
A CSV file is just plain text file with the convention that rows are separated by linebreaks and columns (typically) separated by commas.
What is the structure of your text file and what is the purpose of all this?
Message 2 of 13
(3,339 Views)
It's just the tab delimited measurement data file
Message 3 of 13
(3,333 Views)
Accepted by LED47
I realize I just have to call it up in Excel, I was open you could give me just the extra bit where I would set it as a CSV file and save it
Message 4 of 13
(3,315 Views)
Accepted by LED47
All you need to do is read it as a string, replace all tabs with commas, then save it again.
Of course excel has no problem also reading tab delimited files directly. I still don't see the purpose of all this. Using a comma as column delimiter could get problematic if you share it with someone in a location where the decimal delimiter is also a comma.
Message 5 of 13
(3,285 Views)
Accepted by LED47
It could also be a problem if you actually need a comma in a string value.
I'm with Altenbach. If all you need is something that can easily be opened by Excel, a tab delimited text file works just fine. I do it all the time.
Message 6 of 13
(3,275 Views)
Accepted by LED47
And also, I've had people asking for CSV files, when they meant TAB-delimited. So make sure you have the requirements of the assignment correct before doing unnecessary work.
Certified LabVIEW Architect
Message 7 of 13
(3,247 Views)
Okay thank you very much to everyone I think I understand now
Message 8 of 13
(3,234 Views)
My intention with the following:
Open a text file as a CSV:
Then save the CSV
Result opens in memory as a CSV... Actual saved file is not in the CSV format.
Message 9 of 13
(3,200 Views)
Did you not like the solutions you already got?
Message 10 of 13
(3,182 Views)
