Hello Fellow developers and engineers.
Based on the discussion in this thread I would like to propose the following:
My suggestion is to open support for execution of python nodes on Labview Real-Time targets. This is currently not supported by LabVIEW 2018 Current Gen, even though this version supports executing a python node using the new "Connectivity -> Python"-support.
This should be possible to do on the targets using NI Linux Realtime as the operating system, since Linux treats python as a native application language.
I understand that the execution of Python scripts are not deterministic, which will prevent an implementation in time critical code. That I can follow, but it should be possible to use the python node in lower priority threads or non real-time code, for communication with a REST-API, downloading/uploading files, connectivity to online services and so on.
It has been shown that python can be compiled and executed on real-time targets, here on the forums by Sev_k in this thread: Getting the Most Out of your NI Linux Real-Time Target
Therefore I propose to simplify this implementation and open the support for Python3.
Some additional implementations are essential for the success:
Backwards Compatibility:
Support for this should be from LabVIEW 2018 and forward, since these have support for the python nodes.
Best Regards
Jesper
