I would like a tool that would help identify noise spikes in my data, so that they may be set to NO VALUE or carefully interpolated. In the attached example, I have two torque spikes in my data that are significantly higher than the mean. If I were only looking at one file, I would simply "Set Flags" in VIEW, then "Flags: Remove Data Points". However, I am reviewing dozens of files with several channels of interest.
Peak data points are the most damaging to the components under test, so it is important that we keep the real events and reject the noise.
Concerns with other peak / spike removal options:
nCode Glyphworks has a nice Spike Detection Tool that uses 6 available algorithms to detect spikes. Once it identifies them, it allows the user to see them, prior to performing any actions - this is important, because it allows the user to identify if they are real or noise, prior to taking action.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
