DIAdem Idea Exchange
IanDeaville(ZF)
Curve-related Scaling - make Global, Shared, or Loadable
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
I use n Systems Y-axis viewing a lot, often with groups of channels defined into common axes with Curve Related Scaling.  The only way to save this is in a TDV file, which locks it into that specific layout.  I cannot share a scaling definition with another View area or sheet in the same layout - I have to manuall enter all the details again every time.
Would it be posisble to allow Curve-related Scaling settings to be sharable in some way, so they can be more easily re-used both within a single session, and across sessions, independently of the complete TDV layout?
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
